dazzyboy10
HI there,
For some random reason, our boiler decided to stop working and is giving us an F.75 error code which according to the serivce manual, relates to "No pressure rise was detected on turning on the pump" and states the causes as:
Water pressure sensor or/and pump defective
Air in the heating system, quick bleeder defective
Too little water in appliance; check adjustable by-pass; connect
external expension vessel to return.
Unfortunately i am clueless as how to sort this and as we are private tenants, not really wanting to attempt to sort this myself and our landlord is unavailable to sort it either.
After searching the web I came across a similar problem advising to keep the hot tap running and turning the boiler on/off a few times but for us this didnt work.
Also the bar pressure states at being 1.1 but the dial shows at zero so contemplating that the system may need filling up but this has also put us at a dead end as the boiler is setup in a different way as to how the service manual shows.
This is quite important as we have 3 young children and need to get this sorted asap.
Any help would be greatly appreciated
TIA
Also I have tried contacting Vaillant themselves for technical advice but the phone number they provide is dead.
TIA
