Guest viewing limit reached
Vaillant stand off kit instructions
View the thread, titled "Vaillant stand off kit instructions" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Scott_D
Subscribed
Has anyone got a digital copy of these or do you know where to find them?
Not having any luck with Google and the Vaillant site.
:1eye:
Does it fix to the wall down each side or across the top/middle
Its to replace a boiler with balanced flue
Theres a plate that screws to the wall, a bit wider than the normal one. your frame hangs on that + 2 screws either side at bottom. then boiler hangs on that. I usually find when replacing square flued boilers my new bracket lands were the big hole is. so i rip out, brick up then hang the next day.
i dont like fitting anything heavier than a picture on thermolite.let alone a boiler.
Really? I fit boilers on it all the time. I cut the block so it wedges in the hole, cut it at an angle so it gets tighter as you knock it in. Plaster with a mix of sand cement and plaster. You could core drill it after 30 mins absolutely solid
Reply to the thread, titled "Vaillant stand off kit instructions" which is posted in UK Plumbers Forums on Plumbers Forums.
Scott_D,
GasmanxxxR1,
