P4ULT
hi all i have a problem with a vaillant turbomax it keeps blowing the fuse on the right of the pcb almost instantly any ideas
can you use a multimeter?disconnect pump connector,try it,reconnect pump and disconnect fan,try it.do you have a specific model number?If you dont have MI's let me know as I'll email them to youhi all i have a problem with a vaillant turbomax it keeps blowing the fuse on the right of the pcb almost instantly any ideas
eliminate pump/fan by disconnecting from pcbpretty sure its the pump was gonna disconnect the pump and see if the fuse still blows if it doesnt can i assume that is the problem its a turbomax plus 24kw
sorted thats what i wanted to heareliminate pump/fan by disconnecting from pcb
Reply to the thread, titled "vaillant turbomax blowing fuses" which is posted in UK Plumbers Forums on Plumbers Forums.
