View the thread, titled "Vaillant TurboMax" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
rob jefkins
Hi
Got a few issues with a Vaillant TurboMax combi. The hot water cuts out occassionally and it is getting worse.
Could it be the diverter valve getting stuck or a diaphragm issue???
Any advice appreciated.
Cheers
Rob
pain to change diaphram washer,have to take out clorifer,also the divertor rocker switch sometimes leak so end up replacing full divertor control,bear this mind when pricing it up.
Cheers for the advice.
Has anyone tried to get registered onto the Vaillant installer web at all???
What a ******* nightmare.
I only need to get a part number for a diverter assembley and its asking me more questions than I know answers !!!😡😡
Anyway I've given up now. Just hope my local merchant can order it by description and does'nt want part numbers !!!!!!!!!!
Cheers
Rob
Have you tested the dhw microswitch is working ok, and being switched by the little lever?
regards
I had a problem with the diverter valve on this boiler and found this helpful:
[ame=http://www.youtube.com/watch?v=eqonFQmsaPI]YouTube - Vaillant Turbomax 242 / 282 Boiler Diverter valve[/ame]
Daljit
Still sounds like microswitch to me - Can you "make" the contact on microswitch yourself while running hot water tap. See what happens then.
Reply to the thread, titled "Vaillant TurboMax" which is posted in UK Plumbers Forums on Electricians Forums.
