T
the_bagster
Hi All...
Looking for a little advice.
Recently had a Vaillant VRT392f fitted into my ecoTEC 831 to replace the standard room stat, however despite it seeming to be the muts nuts I am havign a strange issue with it...
99% of the time it works like a treat, however once in a while the boiler seems to act like the VRT392f is not there anymore and defaults to turnign the heating on and running away quite happily turnign the house into an oven.
This happened at about 01:00 this morning. When I looked at the settings for the heating on the VRT392 it confirmed that both the heating and ho****er were in "night mode" and despite the "set back" temperature havign been set to 16 degrees the stat reported that the boiler was in "Auto" and a target temp of "24 degrees".
After scrolling right through the settigns I manually adjusted the target temp to 16 degrees and all has been fine since.
Dont suppose anyone has got any ideas what coudl be causing this? Accordign to the stat the signal strength is at 7 so shoudl be fine.
I am gonna swap the batteries tonight just in case.
Thanks in advance for any help...
Cheers
Carl.
Cheers
Carl.
