F
Foxyuk
Well guys after using same engineer for 20 years patience run out
My temp output on boiler I have increased from 56 to 62 for cold weather is that enough?? Max is 75 on dial
New system amd rads pipes etc all fitted with a siemens thermostat. With receiver. From temp of 16 degrees in lounge takes well over 3 hours to reach 20 degrees. Its 4.57 m x 4.11 m with bigbay windows approx 10 feet by 4 feet, there is cellar under house and most rooms are2 external walls
This room has delonghi double rad single convector measuring 1400 x 600. With a single 1200 x 400 under bay. Is this room under speced??
Daughter room is directly above boiler in cellar. 4.37 m by 3.4 m with windows about 6 feet by 4. In this room is fitted same delonghi double single convertor however its 1000x 600. U put the thermostat in this room and drops 2 degrees imediately. And lucky if moves up a degree in an hour
All rads are bled etc. Have my rads been seriusly under speced ? I'm in glasgow area if anyone can help. Problem is when u use same person too long they become complacent and so do I
Totally scunnered
Totally scunnered
