View the thread, titled "Valiant Eco Tech Plus Boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
V
*Victoria*
I'm such an ejit - opened up the valves to increase the pressure and I somehow managed to walk away without closing them!
The pressure is now too high, with the needle sitting in the red. I have bled the radiator to reduce the pressure, admittedly I left the valves open at the first attempt 🙁 Second attempt reduced it nicely, gave the heating a blast this morning for an hour and the needle is now back in the red.
Advice greatly appreciated. Many thanks for reading.
If you know how to, and you have one fitted on your heating system, fit a hose to the drain-off point, run it to outside and open up the valve. close it when the pressure gets down to about 1bar.. 🙂 Otherwise get a plumber in. IMO ... There's a drain point on the boiler too I believe?
There is a small tap thingy fitted to the house which I recall the central heating man used to drain water when he bled the rads after the boiler was fitted, or was it before! 🙂 I've used that and the boiler is now at 1bar. Will keep my eye on it.
Thank you so much for your help.
PS What's the difference between bleeding the radiator and using the tap thingy?
bleeding gets air out of the system, the tap thingy drains water. 🙂
and Diamondgas is right there are 2 drain points under the boiler, if you look at the boiler the to larger outside copper pipes(flow and return) there are 2 small square nuts under the boiler than can be undone
the pressure will change between the boiler being hot/on and cold/off. if you have the pressure at 1-1.5 when cold then you are fine.
I'm pleased to report all is now well 🙂 Thank you all for your advice and handy tips - very much appreciated.
Reply to the thread, titled "Valiant Eco Tech Plus Boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
