I have a hot water tank in my airing cupboard and a cold water tank in the loft. I understand this is an open vented system. I'm trying to understand what the valves do below. I can see 7 in total which are numbered. Can anyone shed any light?
Good luck using those red headed gate valves!
You might be lucky to turn them fully off and they might turn back on, but they can break.
Lever valves would be best for supply valves from cold water tank to cold taps, hot cylinder feed and supplies to showers
“Gate valves” , so “ last year “
🙂 So true but isn’t it?
Funny how somethings that we used are now so out of date.
Just dread turning them back on , lol
Yep , slightly more expensive but worth the extra IMOThanks guys. So if this was a new install I assume you would use ball valves? Pegler?
It makes me ill looking at them! 🙁😳😵Good luck using those red headed gate valves!
I've seen them (good ones) used as drain-offs!Almost a dead cert of them snapping if you turn them completely off. Terrible valves. Always leave it pass slightly.
why do they hate gate valves so much?
There is actually a simple answer to that Ric. Gate valves were all one could get 30 years ago. When full bore lever valves came out and did a better and cheaper job people stuck back in days of yore insisted on continuing to install them. To compete the prices and quality plummeted so everyone now hates them.
I agree the Pegler versions are superb, but they simply do not belong in a domestic system when full bore isolators are available. ALL gate valves have quite serious flow resistance whereas FB valves have virtually none. GVs suffer from cavitation FB valves dont.
There is not a single domestic install situation I would even consider using a GV these days. 😉
Reply to the thread, titled "Valve Identification" which is posted in UK Plumbers Forums on Plumbers Forums.
