sparksburnout
I have some general questions about plastic pipe systems, as I have not used them before, and am a little confused:
1. Are all the various brands interchangeable? For example Flowplast, "JG" Wickes own brand etc, or are we still in the dark ages of the various brands being slightly different?
2. I need to Tee a plastic pipe into an existing copper one. Is it really satisfactory to use a plastic speedfit Tee to connect to copper, as it says on the fitting instructions?
3. I am taking the plastic pipe into a shower (Triton) and they say that it is not acceptable to use push fit connections onto the inlet pipe. Can't see what the difference is myself, anyone any thoughts on this? I have tried to get a conventional compression to push fit connector but can't seem to find one, can you use a conventional compression fitting with plastic piping?
4. If burying the pipe in a brick wall, is it preferable to house it in trunking to allow movement etc (its just a cold feed) or ok to just render/plaster over it?
