Hello
Would you recommend a vented or unvented cylinder? I have an indirect vented system at the moment. The flow rate from the upstairs taps is low.
We are having solar thermal installed and thus the cylinder will be changed. We can have a new vented or unvented cylinder installed.
What would you recommend? Will the flow rate improve from an unvented? The house was built in 1985 if that is relevant in terms pipework.
Thanks for your input.
