C
Crunchie7
I am trying to help a friend who has just moved into a new home and found the toilet base is badly cracked. The make is Twyfords, but I don't know the model. It has a separate pan and cistern, and ideally she just wants to replace the pan, to keep costs and redecorating down.
The toilet is a 'P' type but the waste outlet is very low. The centre of the soil pipe is only 95mm from the floor. It goes horizontally through the wall at that height. The toilet is 675mm from wall to front. The base of the toilet is very narrow and it is cracked at the bottom. The whole thing seems a bit wobbly so ideally one with a wider footprint would be better.
Does anyone know of a pan with such a low outlet ? I can't find a way to search on soil pipe height. Ideally we need a cheap DIY solution as money is tight
Thanks for any advice
