I
inmcdonalds
Apologies in advance for this long rambling post - I`ll try to be brief.
Moved into house in February. Cold water tanks in the attic, gravity fed hot water cylinder etc. All cold water taps come off the mains. The whole house is half way up a hill, and is supplied by the reservoir another 100 metres (at least) up the hill (to which water is pumped). The cold water main enters the house through the ground below our bedroom.
Over the summer we started to notice intermittent vibrating noise in the cold water pipes going up into the cold water tanks in the attic. We assumed water hammer, so got all the ball valves replaced. This did not solve problem. Vibration was worse at night. To be honest, it seemed to happen with no relation to the tanks filling up or not filling up, although we could stop it by leaving a tap running. Plumber had told us we had pressure of 7 bar coming into house. So we got a pressure reducing valve installed on the pipe coming into our house (just below bedroom floorboards). This made things better insofar as pipes going up to the tank were no longer vibrating. However, pipe prior to the pressure reducing valve was still making awful noise. Next step - contacted the water board as we noticed the Toby? (I think this is what Scottish people call the external stopcock) was vibrating. The Toby was a 4 years old and plastic looking. They replaced it and reported that it was actually leaking. Following replacement the vibrating noise was dramatically reduced. However there is still a audible vibration on the pipe coming into the house, prior to the internal pressure reducing valve. It is much better than it was now the toby is repaired . However it is particularly noticeable and seems to be worse, at night. Water company told me that the toby outside our house was previously replaced around 4 years ago due to failure.
So to summarise - we have a persistent vibration in our cold water mains pipe that seems to be coming from somewhere upstream from our internal presure reducing valve (ie I don`t think anything in the house is causing it and it even continues with the internal stopcock turned off). We have two tobys that have failed in 4 years. We know we have high pressure coming into our house (7bar). I`m wondering whether the tobys failed because of high pressure and/or pressure wave that it making the pipe vibrates. I have no idea what the source of the pressure wave is.
At the moment I am hoping that the noise can be stopped by reducing high pressure coming into the house, and that I can convince the water company to install an external pressure reducing valve. My neighbours told me when they built their house, they had to get an external pressure reducing valve installed in the street.
My fear is, is that it is not the high pressure per se that is causing the vibration, but some other bit of equipment on the network that is failing causing the pressure wave in the pipe. If this were the case, maybe an external pressure reducing valve won`t stop the pressure wave making it`s way to our property.
I`ve tried numerous googles on this subject but nothing similar comes up - which is a bit worrying. Mostly the posts are to do with water hammer caused by ball valves etc but that doesn`t seem to be a problem. It is more like water hammer on the main network...
Any wise words - even some reassurance that this might be fixable would be good!!
dealt with the same issues. lucky you have vibrating pipes, my customer got a filled up basement out of it.
when ive talked to my local water board they will only do anything if the pressure is over 9 bar.
you could have your own one straight after your "toby" installed if they refuse to do anything in the road.
you will also want an expansion vessel installed to your mains cold in the house to take up expansion of the cold water in the mains warming up and expanding while not in use.
7 bar is fairly high, turn off the toby tonight and see if you have noise during the night
yep switching off the toby stops the problem. as does running a tap in the house.
What is the expansion vessel installation for? Is it to stop the pressure increasing in the mains cold even further when the cold water sitting in the pipe warms up and expands?
Yep turning off the toby works. What is the expansion vessel required for? is it to stop the pressure increasing even further when the cold water warms up in the cold water mains?
apologies if double post- last reply didn`t show up..
