Thank you Shaun for your reply and solution.Needs a non return valve fitting on the cold to the boiler and a shock arrestor
Might changing the tap from a mixer to two singles also cure the issue? {they are 45 years old!)
Reply to the thread, titled "Viessmann combi starts when cold, mixer, tap is opened" which is posted in UK Plumbers Forums on Electricians Forums.
