View the thread, titled "vizo 24 boiler repair wanted." which is posted in Boiler Advice Forum on UK Plumbers Forums.
portishead
Hello.
I have a vizo 24 boiler. About a year ago the hot water would run but the boiler kept clicking on and off. I replaced the dhw thermister by the diverter valve as a long shot and it solved it.
But now its started doing it again. I've replaced the thermister again but this time it hasnt worked. If the temp knob is turned up on max it just heats up water for a short while then clicks off though if its turned lowish and the water is run slowly it will keep going.
I'm looking for a heating engineer that knows there way around a vizo boiler to repair it now. Is anyone in or Nr portishead?
Thanks guys.
post [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]here[/DLMURL], you will get a better responce
Reply to the thread, titled "vizo 24 boiler repair wanted." which is posted in Boiler Advice Forum on Plumbers Forums.
