O
oakworth96
Good morning,
When i turn on the hot water tap the spindle does not move to switch on the microswitch,i removed the 3 way diverting valve and checked the workings and the spindle pushes out fine.i adjusted the water flow to see if the spindle pushes out but to no joy,i wondered if the problem could be domestic hot water manifold which is behind the 3 way diverter or it could be a thermostat problem.I could replace these parts but if that does not sort the problem then ive wasted £130 on these parts
thanks🙁
thanks🙁
