View the thread, titled "Vokera compact 28 SE COMBI boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Bhoydavid
Hi there, does anyone know the maximum amount of radiators this boiler is designed to serve? I was at a house last week and the tenant has 10 radiators in the property and 1 (the furthest away
from the boiler) doesn't heat the same as the rest. It isn't choked and doesn't need bled. If you turn another rad off upstairs then the one I mentioned starts to heat up.
im wondering if there's too many radiators for the boiler to deal with?
It's just balancing mate. a 28 kw boiler should be able to heat 15 average sized rads(or 10 small 5 large), it's flow that's letting it down or pipework.
Reply to the thread, titled "Vokera compact 28 SE COMBI boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
