View the thread, titled "Vokera compact 28" which is posted in UK Plumbers Forums on UK Plumbers Forums.
derrybongo
Hi All
Symptom : boiler locked out
I reset boiler and tried to restart calling for heating
sounds as though the fan is running but no ignition sequence
reset and tried calling for dhw
again sounds as though fan is running but still no ignition
reset again and removed vacuum pipe from fan and applied a bit of suction
to switch. ignition fired but stopped on removing suction
to me it sounded as though the fan is running (unless its just the motor) but on the outside of the fan casing is what loooks like a smaller
fan which isnt moving
are any of you guys familiar with this fan ?
is there known problems with these ?
cheers all
Derry
if fan running sounds like ventura blocked put manometer on fan ventura to test
the external fan is for cooling the motor and should move with the main fan if the shaft isnt moving it ithe fan thats not running check for 240 0n terminals fo confirm its the fan and not a power supply problem
Hi
OK guys cheers i will check the above suggestions
i checked for suction on the port the pipe was on on the fan with some leak sealant and no suction was evident
should both connections have 240v ?
im presuming the whirring noise is the motor
is it a complete change motor/fan assembly
and how bad a job rough price if anyone knows ?
i only had 10 mins look at it for a mate as i had installation job on today
cheers
Derry
like stevetheplumber says check power on fan ,check fused spur voltge,check earth,combi wont ignite without earth
hi guys, is there any easy way to test the pcb? i have been to a boiler today (glow worm 18si) displaying fault code f9, went through all the relevant checks over the phone with the technical advisor. it had almost the exact same symptoms, call for heat - fan pre purges then locks out.
after doing all the checks on the components the advisor said it can only be the pcb. im hoping it is as its a mates boiler and if its not then pcb's are non returnable 😱 urgh
Mate of mine, said he put pcb's in frigid for few hours, dried off then installed. Said it worked a treat nearly every time.
Never done it myself though, suppose I thought it was a bit daft all that condensation could short out all kinds.
I will try that bernie and let you know
Maybe I should get a refridgerated van,also then if it gets quite in the summer,I can park up and sell resister flavoured ice cream 🙂
Hi! Puddle
Its supposed to work for hard drives as well, but doesn't seem to last long. For the hard drives, they put it in one of those self sealing freezer bags and stick it in the freezing compartment.
Apparently its not a myth. But I don't know, bit dodgy to me. I suppose though if it was the pcb and its damaged or worn out there is no harm in trying it.
The other alternative is to fault find the pcb and get the spares from Maplins or go to one of those pcb reconditing sites. Mind you pcbs don't like heat so I could not imagine a recon being very good after years in a boiler casing.
But then if cash is tight it maybe worth a go. Its just all that mucking about and no real pcb guarantee after it all.
Mind you the merchants don't usually seem to want to swap them anyway, if you get a bad one off them.
Reply to the thread, titled "Vokera compact 28" which is posted in UK Plumbers Forums on Electricians Forums.
