View the thread, titled "Vokera Compact 29a pressure problems" which is posted in UK Plumbers Forums on UK Plumbers Forums.
U
Unregistered
Hi. I have a Vokera Compact 29a which was installed new nearly 1 & half years ago. The last few months the pressure has been rising into the red and on occasion water leaking a little from left side when pressure too high. Have been bleeding radiators to reduce pressure and sometimes you hear water gurgle in radiator when doing so. Now pressure is below zero and when try to top up using filing loops it sounds as if the water is draining straight out again. Can anyone help?
Please register with us and start a new thread to receive an answer to your question.
Reply to the thread, titled "Vokera Compact 29a pressure problems" which is posted in UK Plumbers Forums on Electricians Forums.
