vokera compact 29he onoffonoff etc
View the thread, titled "vokera compact 29he onoffonoff etc" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
gimmer
after spending some considerable time on this piece of junk i am now befuddled. burner on both ch and dhw mode burner goes out for 3 mins relights for 3 mins goes out and on and on the whole system was full of sludge so i have removed all the crap and cleaned out hex replaced worn pump head and high limit stat . ch and dhw sensors good. cleaned out flue and fan assy. turned to gas valve adjusted max rate to 10mb burner goes off burner pressure fluctuating all over down to to a minus. eventuall y got the dhw to stay on through altering gas pressure but water only warm. heating still going off got 20 vdc at the mod any ideas anyone me thinking blockage in main heat ex
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "vokera compact 29he onoffonoff etc" which is posted in UK Plumbers Forums on Plumbers Forums.
gimmer,
Dotty,
