View the thread, titled "vokera compact he going to lockout" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Dave Walker
hi all hoping someone can help have a vokera compact he that goes to lockout at randem times when in lockout you get a solid red light but if you turn the boiler straight of and on againe it will fire ok. today i have had the heating running and if you turn the boiler on and off allowing it to run for a bit inbetween it will go to lockout. the boiler goes throught its seqence tryes to ignite but does not fire then locksout. if you turn it off and on againe at the boiler it fires no problem. i am thinking this may be the high limit stat am i on the right lines here?
Get your gsr engineer to have a look he will be able to advise you
Reply to the thread, titled "vokera compact he going to lockout" which is posted in UK Plumbers Forums on Electricians Forums.
