rayplumber
right lads will run you through this boiler of my customers bit of a head scratcher
plumber before me changed main ntc sensor not the hw sensor i have been told both need changing at the same time is this correct?
day 1 called out prv running filling loop had been left open to keep the heating on so replaced prv recharged expansion serviced boiler boiler running badly ketteling and bad flow
day 2 stripped the flexi pipes attached to the main heat ex they were blocked so cleaned them out and powerflushed the system
thought that would be it but still no joy red light still comes on after a couple of hours of use doing my head in lol.
i have tested the aps with a multimeter seems ok tested the high limit stat seems okm both ntc sensors change ohms when temp changes
