Guest viewing limit reached
Vokera fault code 79
View the thread, titled "Vokera fault code 79" which is posted in UK Plumbers Forums on UK Plumbers Forums.
O
odonose4
Hello. Does anyone know what the fault code 79 means on a Vokera gas boiler. It was working fine until a week ago when the local town council decided to turn off the water to the town for repair work. I knew it was happening so I turned off the boiler beforehand. A few days later we noticed that it was not heating the water. I opened the valve to fill up the system until it read 1.8 bar. I also bled the boiler at the top of it incase of an airlock but I got water gushing out straight away. I have tried to turn off and reset the boiler as well but it always cuts out after about 30 seconds and displays fault code 79. Any help would be appreciated.
Thanks.
Yes. It means you need a gsr.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location - [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
Reply to the thread, titled "Vokera fault code 79" which is posted in UK Plumbers Forums on Plumbers Forums.
odonose4,
Dotty,
