View the thread, titled "Vokera Maxin24e ignition control board" which is posted in UK Plumbers Forums on UK Plumbers Forums.
bennythedip
Just looking for a bit of advice on the Vokera Maxin24e. When the hot water was running for a while the boiler goes to lockout and needs reset before it will run again for another while. I had an ignition control board from one which I had taken out and stuck that in but the same thing has started happening again. Do I just get a brand new board or is there anything else that could be causing it? Thanks for any help.
Hex is scaled up. Remove Thermister and bob will be related to your mother. Well it will prove that the issue if with hex.
Reply to the thread, titled "Vokera Maxin24e ignition control board" which is posted in UK Plumbers Forums on Plumbers Forums.
