View the thread, titled "Vokera Maxin24e" which is posted in UK Plumbers Forums on UK Plumbers Forums.
bennythedip
Hi all,
Have a problem with a Vokera Maxin24e which is not firing when there is a demand for hot water. The piston on the divertor valve is not coming out to make the microswitch. I had parts from an old boiler so I swapped the valve and the domestic distribution manifold out as I had them as one piece but the piston is still not coming out. Now I don't know if the ones I put in are definitely working but I was hoping for a few ideas to help me get it sorted. It's for an elderly couple and I don't think they have too much so was trying to sort it without costing too much. I've told them because of age of boiler they should start putting a bit away for a new one. Thanks for any help!
I'm not too familiar with Vokera boilers but according to my logic, which isn't always correct, I would think that if you've put a replacement in and it still doesn't work then there's a problem somewhere else.
That said, it might also be possible that the replacement is faulty. What's the standard check for the diveter valve on the boiler in question? If it requires a certain voltage to make it work (the piston that is) then can you either, check that you're getting the correct voltage to the point it's supposed to be at to power the Pistons' movement, or set up some kind of test rig to check it out?
If the pins not moving the diaphragms knackered, just get a service kit
Was just wondering if there was something else I was missing. It's just that the diaphragm and valve were working (I think!!) in the boiler that I changed out, so when the exact same thing is happening with second hand bits I thought they're must be something that I'm missing?
Reply to the thread, titled "Vokera Maxin24e" which is posted in UK Plumbers Forums on Plumbers Forums.
