Vokera pro combi 120HE only fires if disconnect air pressure switch
View the thread, titled "Vokera pro combi 120HE only fires if disconnect air pressure switch" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
A
Andrew Mellish
I have a pro combi 120he. when i try to turn it on, it tries to fire, fan starts but flames burners don't ignite....unless I disconnect the top rubber hose from the fan to the air pressure switch.
I have tried changing the PCb and the air pressure switch, but neither have made a difference.
any ideas?
I acknowledge that the boiler shouldn;t be running without the APS connected, so we have elec heaters on the go.
any advice welcome.
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
STOP MESSING ABOUT WITH IT! YOU DON'T KNOW WHAT YOU'RE DOING!
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Vokera pro combi 120HE only fires if disconnect air pressure switch" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Andrew Mellish,
Dotty,
