Hello guy's, am just looking for a bit of advice, when you guy's fix in a wall hung basin and the wall is made out of plaster board, do you just fix brackets onto the plasterboard or do you cut out the board and put in some ply and a nugging?
Also if you were fitting a shower and the wall is made out of plasterboard, do you cut the plasterboard out and put plywood in and just get a tiler to tile?
Or do most of you guy's actually do the tiling your selves?
I look forward to your advice
Regards
Mutley
Regards
Mutley
