View the thread, titled "Wall hung toilet nightmare" which is posted in Boiler Advice Forum on UK Plumbers Forums.
bigmal
I've foolishly bought online a concealed cistern/frame and a wall mounted wc.
In my amateur opinion, the frame, the back of the pan, and the front face of the pan which the bolts pass through should all be parallel.
That way, they will all clamp up nicely when the bolts are tightened.
But on the item supplied, each side of the front face of the pan which the bolts pass is angled inwards quite sharply.
I'm concerned that when the bolts are tightened, the washers, plastic sleeves etc won’t be in total contact with the pan, and will put it under too much strain.
Don't know if it will work, but here's a link to a diagram & a photo:
[DLMURL="http://picasaweb.google.com/purealgarve/Toilet#"]Picasa Web Albums - purealgarve - toilet[/DLMURL]
cheers 😉
PS.... I think the item supplied is substandard & should be returned, but they're having none of it....
is it an internet purchased as i had a mare of a time getting a refund for a faulty toilet from the internet
sometimes you pay more from the merchant but he doesnt normally quible with taking faulty stuff back
Thanks newbie1.... yes sometimes you get what you pay for.
What I really need guys is someone experienced in fitting these b***y things to tell me whether I'm worrying unecessarily or whether the merchant is trying it on!!! 😡
I think it's a design/manufacturing fault but he doesn't agree,
i would be dubious that a cracked pan might occur if things are flush they normally hold well but that doesnt look promising
It seems like a manufacturing fault to me. If worse scenario happens and your stuck with it why don't you try using the cone shaped rubber washers that you get in close coupled cisterns at the bottom to stop water getting out of the bolt holes. You'd have to chop them down so they aren't so big but they will distribute the weight abit better
Also I know it won't look spot on but if you can find white one's it has to be better than what you've got.
looks pretty normal to me possibly not tightened up in the picture? provided the surface behind the pan is flush you can tighten this up to squash the washer is there room for the top hat plastic to go in further ?
as steve said previously, are you sure the surface, back plate of toilet is flush, had to go to a job a few weeks back and look at similar job(geberit toilet, conceald cistern) pan had cracked due to frame work being out.
iv'e fitted quite a few of these and think your worrying too much as already mentioned if you have the right structure and decent fixings then fit it and enjoy
Reply to the thread, titled "Wall hung toilet nightmare" which is posted in Boiler Advice Forum on Plumbers Forums.
