View the thread, titled "Washing machine connection advice" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all. We are trying to install a new washing machine in our home. The previous owners had a slot for a washing machine. We noticed that there is only one hose in the wall. I would have expected an inlet for fresh water and an outlet to drain away dirty water. Image attached. How do we use this one hose to connect the machine? Please advise. Thanks.
hole bottom right in the back does the plinth come out easily or whats the next until along (right)
also them electrics need sorting (loose face plate)
both plints are screwed on tight to the base. I put my hand into the hole as far as i could but couldn't feel a pipe or anything else.
Quite often pipes will come from under your sink. They may have removed the hoses with the old machine.
While your installing your washer that cable wrapped in tape and smashed socket look pretty suspect. An easy fix while you have access.
Reply to the thread, titled "Washing machine connection advice" which is posted in UK Plumbers Forums on Plumbers Forums.
