View the thread, titled "Washing machine drain connection" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello,
New washing machine is the other side of the dishwasher therefore a longer drainage hose is required. I bought a 1.5m hose which I have connected to the existing hose, looked pretty tricky to replace the hose at the pump! I now have a 28mm rubber connector and a standard straight nozzle which McAlpine detail as max 24mm. Could someone advise the best solution.
Thanks,
Keith
Hello,
Was it an extension or a replacement hose and were both ends the same size plus I can`t see any mention of the 24mm max size you mentioned.
Thanks for your replies. I will remember to remove the blank cap!
The hose was a replacement with two different sized ends, the smaller one was fine connecting to the washing machine hose with a plastic insert and a couple of jubilee clips, just this end is the problem. The 24mm measurement was for the white plastic spigot, so I will do as you say and clamp the 28mm down onto the 24mm. This is in my kids flat which I’m back at on Sunday. Thanks again.
Reply to the thread, titled "Washing machine drain connection" which is posted in UK Plumbers Forums on Electricians Forums.
