water coming out of auto air vent
View the thread, titled "water coming out of auto air vent" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
3rdy71
After finding drops of water under the boiler , i had a look inside and discovered that the screw on top of the auto air vent is missing and water is very slowly weeping out of the hole
hunted high and low but can't find the screw anywhere 🙁
because water is coming out of the hole do i need a new vent?
thx
If it is inside the boiler its a job for a pro, gas safe that is not a prostitute.
If you have a problem you could fry the pcb, or you may have another issue already developing
Reply to the thread, titled "water coming out of auto air vent" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
3rdy71,
3rdy71,
