View the thread, titled "water cylinder" which is posted in Bathroom Advice on UK Plumbers Forums.
boomtheroom
hi there anyone know if i should replace my thermostat or just the probe in my hot water cylinder....the tem keeps varion from 40-60deg c
without anyone touching the dial....
Hi If a conventional system feed from cold water storage cistern? Changing the thermostat within the immersion heater is an easy task, and may well do the trick. Good Luck
Reply to the thread, titled "water cylinder" which is posted in Bathroom Advice on Plumbers Forums.
