Water flow boost
View the thread, titled "Water flow boost" which is posted in Bathroom Advice on UK Plumbers Forums.
M
ma5nasibu
which is the cheapest and most effective way I can get more pressure from my 750ltr tank (situated in the back of my van) via a water hose to a heavy pressure washer. lifting the washer off the van every time is impractical and when in the van gravity is not supplying enough water despite the tank being raised. need a cheep effective pump. but dont know where to start looking for one 😕
thanks for looking
thanks for looking
how much water per minute do you need to feed the washer i think caravan pumps go up to about 12 litres a minute and they run on 12 v electrics youll probably need to wire in a liesure battery via a relay to allow use with out draining the vehicle battery or youll have to keep the van running when using the washer other than that youll need a petrol driven pump
shure and whale are to names that spring to mind google their websites to see if the do larger pumps
i cant see why the tank doesnt feed enough water as i thought preasure washers had a suction effect on the inlet is it possible the feed pipe is to small ?
Thanks for the advice,
@CDs, I checked the websites and got a pretty good idea of how best to try and boost the flow.
@stevetheplumber - this particular kasher washer does not have any suction at all, and the pipe was recomended by the washers dealer.
Thanks for the shure and whale website recomendation
Cheers
Reply to the thread, titled "Water flow boost" which is posted in Bathroom Advice on Plumbers Forums.
ma5nasibu,
ma5nasibu,
