View the thread, titled "Water hammer Help/suggestion's" which is posted in Bathroom Advice on UK Plumbers Forums.
scotty plumber
Ok then so last week i went to a bungalow with two flats inside of it A+B,Roughly about 8-12 years old.
When the chap at A opens his h/w tap at either the whb or kitchen tap there is a VERY loud thudding/hammering noise, this noise happened all of a sudden one day and a heating engineer was called out to have a look over the gas combi-boiler but said all was fine,
i changed over the swift spindle kit's at both hot taps and flushed through plenty water to ensure of no blockage and i also replaced the c/w main stop-valve coming into the property but neither solved the problem, so i called back the heating engineer to double check the combi!
So do you think i have done the right thing and any suggestions on what it could be?
I thought it could be a valve inside of the combi fitted the wrong way around? ( i am not a heating engineer by the way just a plumber!
Reply to the thread, titled "Water hammer Help/suggestion's" which is posted in Bathroom Advice on Plumbers Forums.
