View the thread, titled "Water hammer in heating system" which is posted in Bathroom Advice on UK Plumbers Forums.
AllyBongo
Fitted a Potterton Promax 24SL a few weeks ago, new zone valves and RF2 pack. Boiler is fitted to an open vent system and is fitted exactly to the MI's, close coupled F&E, vent pipe at correct height and angle. However, when the heating ZV closes, there is slight water hammer, and the vent pipe can be heard expanding. At first the vent wasnt as per MI's and a short blast of water came over it. After i re-piped it, this stopped. The MI's dont require a bypass, so one is not fitted, as some of the rads dont have TRV's and there is no over run. Though about fitting one, but i tried holding the HW valve open when the CH one shut and the noise was still present. Any ideas? OR anyone came across this before?
Only had this once, and it was the zone valve fitted wrong way round. Was a Drayton valve, and the paddle shut against the valve seat In same direction as pump and paddle chattered against seat.
Turned the valve around so paddle drops onto seat all sorted.
Wouldn't of thought so, the micro switch will switch off the boiler and pump before the spring closes the valve.
Potterton were out for a look this morning and didn't mention anything about a bypass. As the MI's state, the boiler does not require one
I was just always taught s plan fit an auto bypass for the reason above stops any noises occurring at a later date.
Reply to the thread, titled "Water hammer in heating system" which is posted in Bathroom Advice on Electricians Forums.
