View the thread, titled "Water Hammer" which is posted in Bathroom Advice on UK Plumbers Forums.
novicegas
Anyone fitted a mini arrestor before?
Any tips, think i'd be fine fitting to copper but fitting to half inch barrel not so sure.
Many Thanks
Hi Simonjones I have a problem regarding water hammer I have done all that I can possible think off fitted tee piece on mains pipework in roofspace with 28mm pipework with stopend fitted also fitted prv on incoming mains change floatvalve on tank and pipework is well clipped but problems keeps happeing would be grateful of any other tips
Look at fitting an equlibrium valve instead of a standard part 2. Part 2 float operated valve will still oscillate under high pressure conditions. Although you have fitted a PRV the static pressure will creep up in the pipework when there is no draw off so a slow draw from the cold water cistern like a toilet valve can still cause the valve in the loft to oscillate.
Reply to the thread, titled "Water Hammer" which is posted in Bathroom Advice on Plumbers Forums.
