View the thread, titled "water hammer" which is posted in Bathroom Advice on UK Plumbers Forums.
deano76
Hi guys,
What are the main causes of water hammer?😀
Is there anyone who can help on this matter.
I've had alot of different advice on this problem and was wondering what works best, i.e changing washers in ball valves, replacing ballofix valves, air chambers or installing pressure restrictors..
Deano
depends totally on the installation, ive found as a general rule of thumb (ish) a 15 litre expansion vessel directly after your incoming main stop tap works well in most small domestic installations.
shaun
Basically its suddenly stopping a moving column of water.
It hits the stop and the shock bounces backward and forward down the pipe.
As Migo says, if you give it a nice comfy cushion of air it usually decides it will go to sleep instead of bouncing about.
There are loads of ways you can do things about water hammer though, as well as pneumatic shock absorbers. In point there is a huge industry based on trying to find solutions to water hammer and you can get all kinds of dampers.
Davids right. You often find pipe clips coming away after being fixed,especially perhaps into plaster board.
But then again, how many Plumbers seem to press their pipes into the clips, putting them in "spring" with the pipe tension working to pull them off, rather than lay "natural" in the clip.
I have found that the use of instant shut off taps like those CD valves can cause this problem, as said above it is down to the the kentic energy in water as it moves through the pipes once it get to something it can't move then it will reflex back down the system until it gets the storage tank where it will meet a large volume of water which it can't move it will just reflex again and when you add pumps to the system it can cause to kick in and the whole thing just keeps happening.
Yes, some people call it a pressure wave and its easiest solved by the use of NRVs on the tap that has the CD valves. Standard valves take a second or so to close and reduce the flow gradually to a stop. The CD valves shut it of in less than a second with practically no slowing of the flow.
Every plumber I have ever spoken with on the subject of water hammer seem to suffer from an aversion to even attempt to get to the root cause,
And in consequence end up treating the symptoms without knowing the possible cause.
This is an attempt to explain my take on it,
We are all aware that broadly speaking gas or water flowing through a pipe behave similarly,
I mention gas because I have an anecdotal story about something all plumbers can relate
to by virtue of the fact that 9 out of 10 are drivers, and as drivers all know something about the power of their engines it figures that some will know about the importance of
an efficient exhaust system in producing that power,
I know most vehicles have four stroke engines but my anecdote relates to two stroke engines the exhausts of which to some extent behave similarly,
When the exhaust gasses leave the combustion chamber of a two stroke engine they
enter into the part of the exhaust pipe called the “header” this is a parallel tube that
leads towards the expansion chamber which is conical at the start then parallel then reverse conical it then proceeds along another pipe which leads to a silencer and thence
to the tail pipe,
On the face of it one could be excused in thinking that the gasses go in one end and out
the other the shapes in the exhaust having no effect on the flow through of gasses,
On the contrary what happens is the gas leaves the cylinder and goes into the parallel tube
when this gas reaches the expansion cone it expands and in doing so creates a negative
impulse which travels back up the exhaust gasses to the Combustion Chamber and helps suck out more gasses.
It does not end there, when the gasses encounter the second cone positive impulses are created which travel back up the exhaust gasses and help stop the new charge leaving the
said combustion chamber.
Further impulses are created as the exhaust gasses proceed to the open atmosphere
If one extrapolates the amount of occurrences for example a two stroke engine running
at 10000RPM fires 166 times per second, you can visualize all of the tooing and frowing of the gasses in a tiny amount of time.
A similar situation arises with pumped water it maters not what kind of pump is used they
all produce pulses which become inherent in the water and become evident when the
frequency coincides with the available frequencies in the water fitting.
Think along the lines that a circle is a series of straight edges
In the old days of lead pipes it was the norm to run the pipe past the fitting to form a accumulator and use a saddle joint (tee) to connect which suggest that the problem of water hammer must have been far worse then, probably because they used piston pumps,
I am practicing writing a book and any (genuine) comments on readability and understanding and hopefully confirmation that I display a complete lack of patronization, Etc. would be greatly appreciated,
Water hammer can in the right place and circumstances be useful, any body seen a hydraulic ram in operation ??, and I do not mean one on a digger bucket either
Reply to the thread, titled "water hammer" which is posted in Bathroom Advice on Electricians Forums.
