View the thread, titled "water heater" which is posted in Bathroom Advice on UK Plumbers Forums.
sav
got a faulty Redring Powerstream 9.5kW so im goin to change it for a hyco in95 its running a shower and basin atm
question is does the hyco in95 need a vented tap or not and will it work a shower and basin?
thaks for the help
It has to have a pressure release valve fitted on cold inlet side,with discharge run into correct termination point,does not have need a vented tap
It will be ok for a shower (make sure you have good flow through shower head) and a basin,if you have a redring now ,why change,good units,same price and if you have one now instalation sorted already
Reply to the thread, titled "water heater" which is posted in Bathroom Advice on Plumbers Forums.
