View the thread, titled "water in air pressure switch???" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
G
gary--82
Hi I went out to a Main combi 30 HE today and there was water in the air pressure switch? The tenant said it is a regular occurance (weekly) and he disconnects a hose on switch and sucks water out, when it is put back it works fine. I have never heard of this one so any ideas on what could be causing it??
Condensate and heat exchanger seen clear?? Many thanks, Gary.:hammer:
things to remember with this boiler the flue should be level not fall back to the boiler and the terminal must not be at a angle exposing the air duct to the elements
whys that gasman why should it be level? ive always told to fit the main 30 with a slope regardless
Reply to the thread, titled "water in air pressure switch???" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
