Hello, I thank you for your time. I'm hoping you can help me troubleshoot an apparent long standing issue with my upstairs bathtub. It seems that whenever the tub is filling, water is leaking somehow from somewhere under the faucet and valves onto the downstairs ceiling drywall. I haven't been able to specifically identify where the leak is coming from. It is not from the drain, as I initially thought, I've re-puttied it, filled the tub and let stand for hours, then drained, no water leakage. It's definitely leaking down when the water is actually running. When the water is off, there is no leaking, only when the water is running. I've taken the cartridges out of each valve and ispected, they 'look' good, I don't see water leaking from them when the water is running, so I 'assume' they're good. I see no leaking from the top whatsoever. I haven't been able to figure out how to remove the spout to possibly get a better look at what's going on underneath when the water is running. I've cut a hole in the downstairs ceiling drywall to try and get a better assessment but I can't quite get a good view because of the tub framing and tight clearances, but I can definitely see water pouring down when the tub is filling.
Any insights you can offer will be greatly appreciated. I'm hoping to not have to rip into carpet and plywood and praying it's an issue I can repair myself from top, as money is tight right now. I've taken a few pics to help visualize my setup.
