View the thread, titled "water leaks down the internal overflow everytime i flush" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
K
kazza
i have a macdee arcadia inlet valve (i think) it flushes fine but when its finished flushing the water carries on filling and goes down the internal overflow pipe. This does stop eventually but its got a lot worse. It will also stop if i push down on the inlet valve. Any ideas much appreciated thanks 🙂
Probably a build up of debris and chalk on the washer and the seal. You can try cleaning them and turning the washer over but probably just as quick to replace.
Upvote 0
Reply to the thread, titled "water leaks down the internal overflow everytime i flush" which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
