View the thread, titled "Water Noise into Greenstar 28, but no leaks" which is posted in Bathroom Advice on UK Plumbers Forums.
burnsburger
Hi all,
Hope someone can help me.
I have a Greenstar 28 Worcester
Both the hot water and heating work ok.
The problem is I have a running water noise through the water inlet valve. When I shut the water inlet valve off, the noise stops. There is sign of leaks anywhere that I can see or detect.
Can anyone help me please
Regards
Yes the boiler works fine
The pressure is ok at the moment, I have an internal filling loop fitted, where you put and plastic tool in with two o rings to seal and then you open up the valve, and pressure
Reply to the thread, titled "Water Noise into Greenstar 28, but no leaks" which is posted in Bathroom Advice on Plumbers Forums.
