View the thread, titled "Water Pressure & Shower Mixer Tap" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
SirRawlins
Hello Guys,
I've got a shower mixer tap attached to the bath, and I have a couple of issues with it, which may both be related.
Firstly, the general water pressure isn't great, it runs perfectly smoothly, but it's not what you would call particularly vigorous.
The second issue is that the pull-plunger mechanism which switches the tap flow to the shower-head doesn't seem to stay fully open so you only ever get 50% of the water flow through the shower, the rest continues through the tap. I understand this issue may be related to the water pressure.
I've create a short video to help explain the issue.
youtube.com [forward slash] watch?v=rSa_TS70GMI
Any advice on solving this would be a great help.
Thanks,
Robert
Hello Robert.
has the shower always worked like described or has it deteriorated over time?
what is the water supply to the shower, combi boiler? gravity fed? pumped? mixed pressures?
As above really. I would guess its related to the pressure. It needs a certain amounts to keep the valve open. Try putting your shower head in the bath and trying it again. See if that works. If the valve stays up then its a pressure issue. Buy a new tap mate.
Hi Guys,
Thanks for the response. It's always been pretty poor to be honest, certainly as far as I remember.
I'm not completely sure on the system we have, I can tell you this however:
1. We have a gas boiler downstairs.
2. Downstairs we also have a hot water tank, which I believe has an immersion heater in it, although only used as a backup.
3. The bathroom is upstairs.
4. In the loft there is another water tank of one form or another.
I agree that it might be a water pressure issue - The cold water pressure seems stronger than the warm.
Thanks for any advice.
Rob
Reply to the thread, titled "Water Pressure & Shower Mixer Tap" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
