R
red6
Hi Folks,
I know there's a heap of posts out there with the same issue, but I was hoping to get some answers relating to my set up rather than some yanks problems where they forgot to turn the heater on or something....
I've got a Glowworm Fuelsaver Mk II and noticed recently after fiddling with the radiators in the flat that the water pump is constantly on. The control panel also does not work in the sense that the timer switch has no effect on the boiler so even if the control panel is "off", the boiler will still be on. The only way I can turn off the boiler just now is if I put the dial to "0" as the pilot light still stays on but the pump will still run.
Now, I thought the control panel will be connected to the shut off valves (which I have 2 x 2 way valves tee'd off from each other - 1 is a Honeywell 9135 (not sure if this is model number), the other a Drayton ZA5) and that might have an effect on the control panel or am I completely wrong there?
Any help would be much appreciated and if I've missed out any info you need let me know
Cheers for your help
Red6
Red6
