X
x3x3x3
I have e residential water pumb with a press control on it. After it I placed a pressure reducing valve. The dimensions of the fittings of the press control and the pipes is 3/4 in. The pressuee reducing valve is 1/2in . Do you see a problem with that? I mean will the pump be stressed because of the narrowing from 3/4 to 1/2 ? The reason i am asking is because the prv leaks and must be changed. So I want to see if it is betterto replace it with a 3/4in prv
