N
NeilFawcett
Our water softener has been moved, and unfortunately the little exterior overflow nozel for it has been smashed.
Basically the overflow hose is 15mm, so we're looking for a nice tidy overflow nozel for it on the exterior (garage) wall? At the moment we've just got a 15-20mm hole through the garage wall with a hose sticking out! Blah!
Worse case, I guess I could get a pair of white 15mm push fit elbows, and a 15mm plastic pipe. I'd cut the plastic pipe to length such that the two elbows could be fittered either side of the wall with the pipe through the brickwork, hence holding the whole thing in place by pinching either side of the hole through the wall.
I'd then connect the 15mm overflow hose to the inside one.
Anyone got an alternative?
I've phoned and phoned and cannot find a dedicated overflow nozel like we had!
