View the thread, titled "Water Softner issue." which is posted in Bathroom Advice on UK Plumbers Forums.
Starship1
Hi All. I hope i am in the right place, as its been quite a while since i have visited.
I have a WATERSIDE ultra model MC450S. Its been working quite well, but for a time the over flow pipe outside is constainly running/dripping. Can anyone tell me how i can approach this and if there is a service manual any where.
Thanks...
You could try and completely empty the salt and water out of the storage tank. Then refill with fresh water about 4 inches high. Then reuse the salt that you removed.
if it then after a week or so it still overflows, ( this is the pipe that will just stick through the wall) you will need it servicing.
ring manufacturer for local engineer.
Hi all;
Many thanks for the replies.
The outside overflow pipe is dripping continues, it never stops. I have cleaned the unit out completely, resetting etc, but it’s just the same. I was hoping to attack it myself as engineer call out is quite expensive.
Reply to the thread, titled "Water Softner issue." which is posted in Bathroom Advice on Plumbers Forums.
