View the thread, titled "Water supply to toilet" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi all,
Sorry to be asking a mundane question but my mother lives with me (she is 79) and uses a downstairs toilet. I am having to replace my toilet and can not call a plumber to fit it due to the current situation we are all in. I'm also having to order everything online.
My current toilet is a close coupled toilet with the soil pipe coming out of the back and at a 90 degree angle goes I to a pipe coming out of the ground. The water supply is on the right.
I have purchased a cheap close coupled toilet from Wickes for £47. The soil pipe and water supply are in the same position as my old toilet.
No doubt the new toilet will be a different size so what do I purchase to make sure the water supply from my existing pipe connects and reaches the cistern connector. Also, should I also buy a new soil pipe?
Apologies for the dumb question but I would appreciate the correct name of the parts so I can order online.
Many thanks
Wont really know for sure until you have the new toilet and can measure up the connections. You may or may not need a new pan connecter (Pipe from pan outlet to pipe in floor), McAlpine is the choice of many with a wide choice of pan connectiors to view online. Cistern feed pipe problems will be easy to get around, easier if there is an isolation valve close by.
Reply to the thread, titled "Water supply to toilet" which is posted in Boiler Advice Forum on Electricians Forums.
