No go on the rads as they are column type with crappy little vent
Looks like i will have to get the tool back out
cant you do it via a drain off if there is one?
How meny times have you come across systems where installer HAS-NOT fitted drain of points, find this so annoying !!!!
Yep but normally i change a l/s valve for one with a drain off and would think there's one installed as its a new boiler / system
Reply to the thread, titled "WB filling link with the key" which is posted in UK Plumbers Forums on Electricians Forums.
