Guest viewing is limited
Wedged basin pop up waste
View the thread, titled "Wedged basin pop up waste" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Jr65
Hi all. Any advice on how to release a pop up basin waste that has been pushed down too hard and now will not unpop. Many thanks.
either pick it out with a thin blade driver or try one of those sucker things they use for gu10 bulbs
Undo the trap and pop it back up from the other direction. Could try pulling out the push rod first sometimes the plug is fouling on the push rod that it has been pushed past and it keeps it stuck down.
Thank you - all sorted now. The rubber seal was caught so I rubbed some vaseline on it and then used a thin blade.
Reply to the thread, titled "Wedged basin pop up waste" which is posted in UK Plumbers Forums on Plumbers Forums.
Jr65,
PETE 123,
