Weird noise coming from Grundfos macerator
View the thread, titled "Weird noise coming from Grundfos macerator" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hey guys, hope you're all good
My macerator is making a strange noise which is hard describe so below is a link to a video to make it easier to understand the noise. You can hear the noise at around 10 seconds! I've checked inside the tank and assessed the motor and everything seems clear. The unit still operates as normal with the addition of the noise.
Should I be worried ? I am still under guarantee so I can replace the unit if the noise is a indicator of a failing unit.
@rpm I'm sure you might have an idea 😀
Reply to the thread, titled "Weird noise coming from Grundfos macerator" which is posted in UK Plumbers Forums on Plumbers Forums.
hsadat,
Aquarius,
